YX140 oil cooler
4.5K views 6 replies 5 participants last post by  Jordo
I started flat track racing my SDG with YX140 motor so I thought I should add an oil cooler. I don't like the complicated hoses and upper mount type so I made a head mounted one from the original link banjo fittings and some copper tube and sheet. Silver soldered it all together and ran it, one tube is much cooler than the other so it is working. Simple and light.
#6 ·
I wasn't going to paint it but copper turns nasty looking after awhile and even worse around silver solder joints. Also, not visible, there is a rubber bumper on the little tab on the far side that damps it against the head so it won't vibrate and crack (hopefully).
