Z50 sloppy forks!
2 reading
16K views 25 replies 10 participants last post by  66Cooper
I have been redoing this 69 z50 and one of the problems was that the forks had a lot of play front to back. After researching I found that it needed new fork guides. I purchased a set and did the fun dirty job of replacing them. Now that the bike is almost all put back together, I gave it a quick ride and the forks are worse! It seems the guides had way too much play in them. Is there anything else that i can do to eliminate this? I have only installed the front brake so when i was test driving it today the forks would flex like crazy when I hit the brake. It makes me nervous that something may go wrong. Right now I am the only one riding it but in a few years my 7yr old son will get it. I sure wish I would have realized this before I put the forks back on. Those little ball bearings in the stem are a PITA. If anyone is interested in pics i can post a few of my pseudo restore.
Jason
#5 ·
The guides were really loose on the fork legs. I bought the ones listed for my bike. I wonder if the fork legs are some strange aftermarket? I will have to try the piston slides but is there any way to make the guides tighter? Will I have to find a way to machine some from a chunk of plastic?
#7 ·
Are you positive the play is in the forks and not coming from the bearings in the steering stem assembly?
If it is the suspension bushings causing the problem then it can only be a few things.
1) you ordered the wrong part
2) they shipped the wrong part
3) the hard anodize coating has worn off on the inner diameter of the fork legs causing the sloppy feeling. There is no real way to fix this. You could send them to get re-coated but the cost would be more then finding another set in better condition.
I don't see an easy way to fix this if that's the case. Trying to thicken the bushing is going to cause you more binding problems then solutions because the hard anodizing doesn't wear evenly. Like the bottom of the tube may be fine but the middle is worn and a larger diameter now then the top and bottom. A larger shim will work in middle only and bind up in the bottom or top.
Again this is my educated guess I am not there to see the product.
#12 · (Edited)
They are aftermarket china parts. Correct Honda ones are still available for about $6 more. The delron bushing I mentioned above are vastly superior to the Honda bushings. Lets see a picture of your fork legs and if they are badly worn. I have seen the delron bushing improve badly worn legs.
#15 ·
I got the forks torn apart. The new guides i bought were way too big. There was so much slop. The bars seem to be in pretty good shape, you can still see the chrome. Should I just order some oem guides or go with the delrin? If I get the delrin where should I purchase them from? Thanks for the help everyone.
#18 ·
I am in the process of rebuilding my entire front end. You have got them apart, which is the messy annoying part so might as well do it right. Delrin bushings are a must. TwoBrothers, Fast50s, Tbolt, and others sell them. 100% a MUST. They really do a great job. While you are in there, install those upper bushing/collars as well if you dont already have them. Not sure what you currently have but a spring upgrade might be a good idea as well to firm things up a bit if you are an adult rider. Lastly, tapered neck bearings are a good idea to install. You have it all apart, better to get it all done at once and then never have to think about it again.
#19 ·
Thanks for the info. I am ordering the delrin bushings right now and I think I can get the upper collars from my local bike shop. The springs seem good especially since they will be for a smaller rider. I put all new ball bearings in the neck when i put it back together and they seem to work great. Plus, I only pulled apart the forks without taking the whole assembly off.
#25 ·
If grabbing the jz style "anti rattle " piston slides as above in post 3 ...make sure you get the longer roll pins to suit them as well ..
An old trick if your fork tubes are worn inside was to unscrew your fork leg collets , draw the white bush / guide down ,,,,,then cut up a beer can and wrap that arround the white bush / guides ..
Slide it back up into the fork leg and do up the collets .
Bush mechanics bodge .
