YX head on KLX motor
1K views 13 replies 8 participants last post by  five21racing
Hi there,
I seem to recall many of you putting YX150 heads on your klx motors. A friend of mine wants to do the same "low cost" mod, and would like to have the basic guidelines.
Has anyone posted something easy to follow? I didn t find anything with the search button ;)
Thx,
Ben
#6 ·
507 brett said:
i got one on my tb/2bros 155. runs nice, but it ticks... :/
Unless you cut deeper valve reliefs; that ticking is the valves hitting the top of the piston. I had a TB 143 clyinder, 55mm crank, and a new style TB piston.
benjaidafufukil said:
So basically you guys are telling me it s just a simple bolt on? No machine work needed?
I would have been fine if I would have cut deeper valve reliefs in the piston.
#9 ·
Aight ;) I guess he will recut the piston pockets and also use 2 base gaskets... that should do it.
Anything special for the pipe or any stock / aftermarket pipe will do?
