What size main jets are you guys with 28mm carbs running? I'm at sea level as an FYI. Currently running a 125 which seems to be too small.
supernes550 said:What size main jets are you guys with 28mm carbs running? I'm at sea level as an FYI. Currently running a 125 which seems to be too small.
FastMC said:I have that carb on my 146 with ported BVH. Fell flat on its face with a 125 MJ. Too fat. Found 95MJ and 42PJ to be ideal. Also at sea level BTW.
will do. i plan on heading to the local stealership some time this week.Z said:If you were running a 125, you were too rich.
Start with a 98.
can't tell.BILLYBIGWIG said:it would depend on which needle you have aswell? do you have a jjh?
big pete said:Any reason why you ditched the VM26 for the PE28?
sup dude? what's up with your zb?hooptytank said:What's the latest?![]()
