Tire pressure?
1 reading
40K views 22 replies 12 participants last post by  Luckystar64
This may seem pretty basic, but what tire pressure should I be running in my KLX110 tires? I've been running around 11. My bike has a Works Shock, and a KX60 front end if that matters at all. I run 13 PSI in my YZ250. Am I doing too much? Too little? L*64
#9 ·
muuurph said:
are you guys running tubes? i run stock tires and tubes and i have 30 psi recommended is 32...and my tires like arent all that hard.
if i buy the tire lock does it seal the bead and i can ditch the tubes?
like these guys say you can run as low as 12 pounds. I usually run14 on my big bikes but my mini usually gets flats from the rim pinching the tube on hard landings with low pressures, so 18 - 20 lbs usually fixes that. rim locks keep the rim from spinning on the tire which keeps the valve stem from getting ripped out of the tube usually causing tire pressure of 0 lbs.
#23 ·
Well-- That's a big spread! My bike kinda seems like it likes to wash the front end a bit on dry hard pack- like at TV Land. I was thinking that maybe it was tire pressure related. Maybe everyones tires seem to wash out there-- I don't know, cuz' I've only been riding my KLX since August. Except in my backyard. I guess I'll try 17 and work my way down. ---L*64
