TB V2 Race Head yx140!!
2 reading
16K views 9 replies 6 participants last post by  Ronski140
Iv been checking out some of tbolt's awesome bolt on power parts for yx140 and I'm just wondering if this kit will all bolt straight on with no other fuss or effort just put it in and go also what power gains I'd be looking at??
TB Roller Rocker Race Head V2 146cc Big Bore w/VM26 Carb Kit China 124cc & 146cc
- Roller Rocker Arms
- 28.5mm intake Valve
- 23.5mm Exhaust Valve
- 5mm Valve Stem
- 23mm Exhaust port
- Matching High Compression Piston
- Head kits include all hardware
- 57mm piston with rings, pin, & clips.
- 57mm Aluminum Cylinder
- VM26 Carb Kit
- High performance race camshaft (for the Race Head only)
- Head gasket kit.
To run in Chinese 124cc & 146cc engines 13mm wrist pin
#8 ·
#9 ·
#10 ·
  • Roller Rocker Arms
  • 28.5mm intake Valve
  • 23.5mm Exhaust Valve
  • 5mm Valve Stem
  • 23mm Exhaust port
  • Matching High Compression Piston
  • Head kits include all hardware
  • 57mm piston with rings, pin, & clips.
  • 57mm Aluminum Cylinder
  • VM26 Carb Kit
  • High performance race camshaft (for the Race Head only)
  • Head gasket kit.
i Race Grasstrack here in the uk, Riding in a class called GT140 the Guys who run the TB head are flying. an Ex Australian speedway Rider Glyn Taylor is putting these Engines Together and this year gor the top 3 podium places.
you can see the Difference once they hit 3rd Gear they fly. we basically Ride on oval Grasstracks and speedway and gear to use 1st 2nd and 3rd gears, you can see the speeds on you tube where i put up onboard videos. search Grasstrack GT140
the Engine i use is one by a company called ooracing.com which has a polished,ported and skimmed head the Electrics ie stator coils are all to produce a bigger spark with a High compretion piston, i also Run a 26mm Nibbi carb as per ACU Rules. and the TB Heads are still much quicker. im looking at getting A TB Head and Piston fitted on my spare Engine. but i Beleive Head is ÂŁ520 the Piston that Glyn has worked on is ÂŁ80 plus ÂŁ35 for him to put together
