Stock horsepower vs. bbr pipe, carb, and filter?
8.2K views 5 replies 4 participants last post by  yz250f45
Hi all,
I just got my boy a stock crf110. It's quite peppy and quiet so I'm curious what its stock power is and how much of a difference adding the bbr pipe, 18 mm carb and uflow filter will make?
Any information is much appreciated.
#3 ·
^ WRONG!
On a CRF110 it's the stock carb that is the bottle neck. Going to a biger 18mm carb will give you the biggest bang for the buck. Pipe is 2nd and rev box is worthless until you put a cam in it.
Stock bike makes 4.5 hp
Carb, Pipe, Cam, rev box is about 7.5 hp. (Huge gain for the buck)
#5 ·
You don't "need" it... But just a pod filter does flow better then the stock air box. There is a spark arrestor in the air box that is VERY restrictive. Remove the screen mesh and steel plate that are both under the air filter, and it will no doubt help top end pull.
