For a while I was pretty curious about the reverse intake too.
Don't waste your time with it.
It'll look cool and the filter will stay cleaner, but if anything, it will reduce power by disrupting air flow.
Do a search on this topic and you'll come up with a couple topics. In the most recent one, one of the guys who's name I can't think of(*Edit Cyclerider*), gives a brief example of what the intake tract should look like (since we can't have a perfect one due to the horizontal motor). Basically you want as few curves and corners as possible. Or at least large steady ones. If you reverse the intake, you both lengthen it, which will likely not benefit the power in the sense most people want, and add extra and opposite curves to the intake. It effectively makes the intake tract an screwed up S. Which is bad.
In theory, if you had the head ported to accept the carb in the 50 location, it could make for a really good intake tract. But that would be a lot of work and $$.
As for Preston's Ram-Air effect.. keep dreaming. To even THINK about a ram effect, you'd have to have it in nice clean airflow, and then be moving at about 60mph before it stood any chance of becoming effective.
