What tire pressure do you guys run without a rim lock in your rear tires and not spin the tub?
badmatt828 said:I tried from 15 to 45psi with out a rim lock and no luck. The tire would still spin on the rim. You should get a rim lock.
coletrain01 said:i fill it up until its hard. i never had a rim lock when i had a stock motor. but i spun a tire when i put on my 143 so i put one on now. tire pressure dont even really matter with these bikes imo
BIZBKAK248 said:TIRE PSI IS HUGE,makes even more of a diff on these bikes-specialy if the mtr's built..
missingpieces said:man, alot of you run some high PSI!
dude, get a rim lock. problem solved. personally, i run around 13-14 psi on a klx 143. riding on clay and sometimes sandy-ish terrain.
my $.02
JCMINIS said:rim lock,11psi,moose heavy duty tubes,756 tires,143 kit....no problems
The heavy tubes add some weight BUT I HATE FLATS.My goal is to put on a new tube and tire and not take it off till the tire is worn out.
thegreenripper said:The smallest rim lock I could find was a 1.6 and I can' t get the tire to seat fully with it in. Even at 75psi.
