I've been getting a few PM questions on the Classic 125 so I thought that I would start a thread of my limited experience since I've only had the bike for a few weeks.
Assemble was pretty easy and made easier since Pitster threw in the optional center stand/ off road pegs assemble. I have center stands on my bikes/scooter. Took me about five hours or so but I was taking my time. The wiring diagram did not color match the tail/brake and rear turn signals which I had to install. Used a volt meter to figure out the wiring. No big deal.
The owner's manual is very weak since it's for some CT70 clone and doesn't mention the Classic 125 at all.
I had to remove and clean the fuel tank of bits of plastic. It holds about a gallon of fuel and has a nice billet cap. (Correction on the fuel capacity as according to the part manual Gary G. sent me, the tank holds 5.5liters or 1.45 gallons.)
The front disk is very strong and the rear drum seems up to the stopping task.
No word on top speed since I am doing an easy breaking. Up to about 90kms on the odometer. Will GPS it after I replace the dinky 3.10-10 tires with 120/90-10s.
Engine runs well, cold natured, choke,and is easy to start with button or kick.
Seems to have good power.
Appears to be geared low but I will wait on gearing changes until after break in and tire swap.
Added a right angle fuel filter and routed the fuel line under the carb. Still getting a little fine bits of plastic in the fuel filter. They are so tiny that the filter in the fuel valve doesn't catch them.
Added a Walmart ATV seat cover and cooler that I had laying in the shop. Just tied the cover on to try it out.
Well anyway, so far so good with the Classic 125. It will pull my 200+ lbs up my steep gravel driveway just fine. Waiting to get my tag in the mail from FL (FL resident, spend 6 months in WNC mountains) before I venture too far from home.
Oh, had to drill new holes in the license plate holder, wouldn't fit tag.
Everything is working and I am happy with it so far.
