pe 28 vs pwk 28
29K views 20 replies 14 participants last post by  pitsterprox4
What are ur guys thoughts on these ? im planning on putting 1 of the 2 on my v2 155z and was wondering which will work the best and wat the differences are
#2 ·
the TB 28 it a PE28 copy with the right needle in it from the get go and i love it easy to tune and makes geat power. jseeint for stock 155z (for me ) has been 44 pilot 100 main needle in the middle. on a V2 155 it has been 50 pilot 120 main needle in the middle.
with the pwks if you dont have a good throttle spring they slide can float and letting can be a bit*h
#5 ·
I run the PWK28 on my Lifan 150. I use a JJG needle, a 107 main, and 42? pilot.
The fix for the throttle spring is to replace it with one from a stock KLX110 carb. I did and haven't had any problems with the throttle sticking.
The TB28 carb has issues. The coating on the slide flakes and causes it to get stuck in the bore.
#7 ·
The Nutty Professor said:
Can anyone advise on the right jetting for a pwk28 on a YX150? I seem to have a problem on the bottom and it smooths out but still isn't what it should be. I have no idea what's in there now. One of the first things I'll do is replace the spring as recommended but that still leaves the jets???? Anybody????
like fastfreak said u need a 4stroke needle like jjj , jjh or jjg
#8 ·
chaddy721 said:
i'm nota fan of the tb28 carb the slide sticks inside the carb and its just cheap... i have the dslide 28mm on my x4 and its the ticket..
have a few guys raving about TM28 too
#15 ·
well not to confuse anyone but they didnt have my engine together so i opted to throw down the extra cash for the 184 big bore kit .so now i have the 184 kit with a v2 ,billet clutch pitster decomp kit and a heat wrapped titanium fmf exhaust. so my new question is can the pe 28 handle all this and wat kind of jets should i expect to run ? elevation is around 2200 ft
#16 ·
Maybe I should have explained better. I did not get the carb new so I don't know what jets are in it. I can already see I really need a needle the one in there is scored. But getting a new needle and using the same jets might cause the same damage. There are no markings on the needles. I know the pilot is probably stock but the other isn't. I just want to change out both and be done with it.
#21 ·
taz69 said:
I have a 184V2 headed YX and a PE28 on it. I live in NC 1,000 feet above sea level. Its 90 here and I have a 40 pilot needle in the middle or clip on 3 from top.. And i am using between a 120 and a 125 main.. This will get you REAL close to what you need...
thanks dude i guess all i need is my motor now!! how much of a difference did u notice from the motor being stock til now ?
