-->.:PARTOUT, HUGE lot of parts; new and used klx110 forks,swingarm,shock,more. :.<--
2.5K views 33 replies 15 participants last post by  Lowtoy
-->.:pARTOUT, HUGE lot of parts; new and used klx110 forks,swingarm,shock,more. :.<--
contact: mxscholar at gmail.com
KLX110/DRZ110 Parts for Sale, sorted by category.
Parts prices do NOT include shipping and prices are
non-negotiable unless multiple items are purchased.
Plastics, Frame, Seat, and Rearwheel are NOT for Sale.
Misc.
Used Sik110s Skid Plate - $30
Cables/Controls
TB billet throttle w/throttle cable. Sold
Stock throttle & Brake Cable - $5 each (free shipping if you buy both)
Engine Parts
YX Head with YX cam, Ported and rebuilt by Castro (“dood”), very fast, 12 hours on it since rebuild. -$140 or $165 w/TB intake
OEM wiring harness in good working condition. $20
Low hours, great condition Kitaco SE (143cc) piston with rings, wristpin, and circlips. $30
Used red baron pod 26mm air filter - $5
Used 26mm uni air filter dual-stage - sold
Outwerwears crf50 style air filter prefilter - sold
Red Baron Kamikaze 26mm Carb w/2 extra main jets - $50
(replica of vm26, easy to jet, works basically the same)
Suspension
Red Baron KX65 fork kit. Complete black kx65 forks with aggressive springs, disc brake kit (formula, same as on Marzocchis) that will work with stock hub, and axle and axle reducing spacers. Also comes with ASV black unbreakable brake lever. Comes with brand new Red Baron tapered bearings. Low hours on these forks. $400
OEM forks with BBR Dampening rods, BBR hd springs, and Race Tech Emulators. Best stock fork set-up you can get. Great condition, no leaks. Comes with oem bottom clamp and two bros. gunmetal top clamp. sold
I-shock MBV2 shock with 14mm shaft (most are 12mm) and set-up for a 150+ lb. rider. Comes with shock wrench. - sold
Red Baron +2” Swingarm for stock-length shocks. Great condition, comes with sik110s chainguide, rear axle and nut. Low hours on swingarm. $240
Wheels/Tires
OEM front wheel, excellent condition, spokes tight, true, straight. Comes with tire and tube. $40
OEM hub with Excel front rim, stock spokes. Good condition. Comes with tire and tube. $85
OEM hub with Pro Wheel Racing rim, hd spokes, like new. Like new Starcross tire and tube. $120
Brand new 14” Dunlop D756 Front Tire - $20 add $5 for HD Tube
Brand new 60/100 HD Front Tube for 14” Tire - $5
Sprockets
New JT countershaft sprocket 14T - $7
New Red Baron countershaft sprocket 13T - sold
Used Takegawa countershaft sprocket 15T - $5
Used Two Brothers Blue 39T rear sprocket. Great condition. - Sold
Used OEM 33T rear sprocket - $5
Pictures @ KLX110 Partout Pictures
Pictures are being added, pm me if you don't see what you're looking for.
#11 ·
Re: -->.:pARTOUT, HUGE lot of parts; new and used klx110 forks,swingarm,shock,more. :
PM SENT FOR THIS QUESTION
Used 26mm uni air filter dual-stage - $10
Outwerwears crf50 style air filter prefilter - $10
***do these two parts work together and do you know if it will fit on a klx110 with a vm26 without rubbing the fender?
I WANT THEM IF IT WILL WORK
PLEASE PM ME THANKS
