Noooo I Cracked The Motor Mount
1 reading
6.4K views 32 replies 18 participants last post by  pandrew3
my buddy was checkin the slack on my chain and he noticed my motor moved a little bit,when i checked it thougt it was nothin too bad i noticed a hairl line fracture on the top motor mount............
what should i do, buy a new frame, bagg it till it break compleetly then weld it up or buy a new frame and build a new 50 up
what should i do............i dont know help me ouuut
#7 ·
will it get worse with a craddle? or just stay the same? ive got 3 buddies with this, all of them are thinking about buying new motors/fifties cause the problem intimidates them... will a regular welder work? i figured it was some sh-t pot metal or something that couldnt be welded
#8 ·
No it is aluminum, any competent welder should be able to do the job easily.
#10 ·
Take the engine 100% out of the bike. Have an aluminum welder add on a small piece of aluminum to the top of your engine mount for added protection. Weld, attach, weld.... done. Then put it back in your bike and you're set. Done this a half dozen times on different engines. Works great.
#14 ·
same happened to me
i welded it all thick
and wahla
better than before
