New 57mm kits for honda and xtreme =146cc
1.7K views 23 replies 6 participants last post by  TRT
we getting in some 57mm bbks for honda (69mm tall) and xtreme (78mm tall)
this will be the xtreme 146cc kit alot of guys have been wanting
when mated to the pro stock close ratio trans and ported tb race head look out
on the crf50/70 with tb 51mm crank =130cc
case boring may be required
#6 ·
Order placed. What is the required size to bore the cases too, so l can get them bored while waiting for them to be delivered?
#14 ·
B&N Minimoto said:
what is the biggest cylinder bore you could go on a crf 50 case im running a 54mm tb cylinder i was thinking of boring it out, is that possible? If so how big or do i need to resleave it? or go with a diffrent cylinder?
you will need a different cylinder
were doing this in 57mm to keep stock of pistons down
this way all 49.5 and 57mm w/ 13mm cranks will take one piston and we will stock these pistons ,cylinders and gaskets
we will also be getting some shorter honda type pistons in 57mm
if your a serious buyer and willing to bore out your honda cases post and email me so i can get more pistons to fit your needs
#15 ·
chrisc161076 said:
Are there going to be any bigger valve heads developed for the Xtremes like the GPX engines?
we are testing some heads with bigger valves for honda /xtreme but wont have any news till after vegas
#16 ·
B&N Minimoto said:
Vince, do you have a price yet for the honda?
i have this set up for honda priced and ready
TboltUSA
but the trx90 kids i sell to cant go 57mm due to class 125cc rule
to set up the 57mm kit for honda 50/70 we need to get special pistons
so
its going to be a little more and we will let you know when its ready
i can take an email order now but it will take a few weeks to get to you
#23 ·
chrisc161076 said:
What is the miniumum clearance you allow from the outside of the studs to the inside of the case?
please just wait till you get your kit and you will be cool
#24 ·
You definately will need to bore the cases and its not a straight up bore...it is an offset bore..just did an engine for me motard bike......The only problem I am having is a piston for the +R big valves..already burned through some pistons trying to clearance them....leve and learn...I also have a 56mm stroker crank.....thats where the clearance issue comes in.......
Nick, hit me up for more info...
