My Linkage X4R
10K views 115 replies 37 participants last post by  mxminirider44
My Linkage X4R PICSS!
Yes the title is correct. This bike is truely amazing. I would say the builders name but im not sure if he wants me to annouce it on the boards. If he wants to he will post in this section.
Linkage is a must. I am a believer now. I only road it around my neighborhood over a few speed bumps that used to actually make me jump. Now the bike stays on the ground and flows with the bumps instead of bouncing off them.
The setup is amazing, it truely is. I will have pictures up sometime tomorrow. The bike is filthy and need to tighten up a few things.
Another thing on the linkage. It makes the X4R sit low. I mean really low. If you didnt know this already the X4 model line actually sits alot higher than any fully built klx110. Now with the linkage the bike sits normal to built klx's. it is amazing!!!!!!!!!!!!!
So happy with this product.
#24 ·
Brandon, which bolt hole is the front of the link in? This is adjustable , And working very close with Pitster Pro, we are looking into making this a kit. This is the first completly bolt on set up (Brandon did need to grind (adjust) a little because of a little differences in the frame and we are looking into correcting this) but for the most part a bolt on.Just one more innovation from NCC and Pitster Pro. and for you TTR lovers keep your eyes open.
#26 ·
Kurlon said:
What action rate are you shooting for with this setup? Rising, falling, dead linear? Lowering the X4, proper sag, and a nice linear rate setup screams indoor kart track monster all of a sudden. Too bad my NSR wheels are too wide to fit the swingarm and forks. :p
It is a progressive rising rate, with a quick curve increase at the last few inches of travel. now that this suspension has race sag, it will keep the wheel incontact with the ground more, it has two settings, one that is softer(slower) and lower, and one that is quicker (harder and about 3/4inches more travel)that sits up a little bit more for tighter tracks .
