I had to take the whole caliper off to put the wheel on and now the new mag wheel won't give clearance to put the caliper back on. Should I put the stock disc brake from my mx wheels?
Is the rotor to big? If it's just the rotor that's to big out your stock one back on and try it. If it fits order a rotor that size for the new wheels.
on mine, you can slide the rotor into the caliper as you slide the wheel into the forks. you just have to put the wheel in at a slight angle to get the disc started into the caliper.
