Marzocchi/ Ktm Front Brake Question On Xr50
13K views 6 replies 5 participants last post by  Dreamcrusher67
I was hoping to get a little info on these older conventional Marzocchi front forks and KTM hydraulic disc brake. I purchased the front fork kit used and the brake never has worked. Really all I know is Ive got a KTM front wheel, disc brake rotor and caliper. Are the forks KTM's as well and marzocchi just beefed them up and slapped their name on them? Is there some trick to bleeding the damn brake? The brake lever never builds up pressure no matter how many times or ways i try to bleed it. At what point am I looking at replacing the master cylinder? The caliper? I have included some pictures of my setup and any help would be greatly appreciated. Thanks.
#2 ·
Usually those brakes have to be bled from the caliper up to the master cylinder using a syringe and hose, you might try getting a bike shop to bleed them for you but I've heard from others that you DO NOT tell them it came from a mini motorcycle and say it's from a mt bike instead or they won't even look at it.
Marzocchi makes forks for KTM bikes; yours look like they are from a 50 SR, they also make the forks for the ktm65's, but with a real motorcycle brake
#3 ·
ya the older ktm 65sx used marzocchi forks like those. I have the brembo master from the 02 or 03. You made need a power bleeder or reverse bleeding it may work. If you dont know that means opening the nipple and using a brake syringe and pushing the fluid up into it and forcing the bubbles up. Also on my brakes I used a small tool and tapped the line while pumping it and I got a lot of bubbles up that way. Of course start at the bottom and tap upward to force the air up. Hope that helps. If not it could mean your master needs a rebuild.
#4 ·
Hey thanks for the input. I might just take it to a bike shop like zwieble said. I've tried the reverse syringe method with no results. Although I haven't tried there trtr tapping trick yet. The bottom of the master cylinder was pretty nasty dirty so that may have something to do with it. Thanks for the help and input.
#5 ·
Make sure your lever adjustment is all the way out (if it has any). Try taking the caliper off the forks and turning it in all different directions while tapping it with a wrench to try and get any air bubbles up and out of the system. Sometimes air gets trapped in the banjo bolts too. If it still doesn't work, then you probably need to reseal the master and caliper.
#6 ·
Ye, check, if the lever has a bit of free play and adjust it all out. I installed this same complete brake on my Marzocchi 35mm Shivers. It works hell better than the standard Formula 2 piston brake. I only touch the lever and the bike imidietly stops. Much better setup!! I bled it in normal way-few times push the lever and then worked with the bleeder on the caliper. I made it few times to change all the fluid for a new one and i had no problem with that. Im also using the oversized brake disc and I used the stock caliper bracket for the 200mm disc and 2 piston standard caliper, only made the holes in the bracket bigger from 6 to 8mm. I would recommend this setup for anyone alse here, much more stopping power, no fading also. It looks hell small, but works really good!
