Lights for NSR 50
4.5K views 27 replies 5 participants last post by  NCNSR
Can someone give me some websites, phone #'s etc...for lights, brake lights, side mirrors and a horn for the NSR 50?
Thanks
PS - newbie btw...lol
#2 ·
Thanks
www.bajadesigns.com
Redline Powersports
and you can try dan@honda50.com
Those are the three i used to get everything i needed..........All the parts and part# are in the resource sticky if you chose to go Genuine Honda JDM like i did........$$
#6 ·
NCNSR said:
"Stuff" You bought 2 blinkers and forgot to get the screws..........You make it sound like you loaded up there.........BTW I will give you $75.00 for your pipe..........So you can get more "Stuff"
HAHAHAHA, wow.. you are just one funny dude. haha, that really just made me laugh.
yeah like i was saying, i got all my stuff there,they are decent people, they should be able to get your genuine honda parts that are discontinued. check out the 98 JDM nsr50 manual for the part numbers.. good luck
#7 ·
#8 ·
gward10 said:
hey Guys,
What light kit did you use from Baja designs?
getting mixed messages here:
this one:
https://www.bajadesigns.com/NET/P-121300WT/Dual+Sport+Kit%2c+Ez+Mount+Kick+Led+Wt
or this one:
https://www.bajadesigns.com/NET/P-121300RD/Dual+Sport+Kit,+Ez+Mount+Kick+Led+Rd
and do i need to order another headlight or should i ask them to find one that fits my 2004 NSR 50???
Either one, they are the same just in wt white or rd red,That is what i used and ordered it with the LED option i ended up scrapping most of it but the harness as i got a real battery and LED bulbs in JDM fixtures,But that is the kit to get and you just remove the stuff from the shell,The headlight they send you is too big and will not fit the NSR,The JDM NSR headlight is discontinued so Redline is your best bet for that, I dont know if you can get a similar size headlight in the us but i am no expert.I was really bent on using as many Honda parts as i could but this is not the cheap way to go,If money is tight you can use mostly all of the Baja stuff and be up and running fine.It is the Headlight that is the rub,Everything else comes in the above kit.Horn,Clamshell,Battery pack etc. etc.
#9 ·
Ok thanks man! Then i will order this set. I also ordered the headlight as you recommended from Redline. (your right not cheap! 510 for the baja kit and another 70 for the correct headlight).
NCNSR - Would you recommend i take this kit to a professional, honda dealer and have them put it together? I dont feel comfortable doing it myself. And where did you order review mirrors?
Thanks bro.
#10 ·
[quote name='gward10']Ok thanks man! Then i will order this set. I also ordered the headlight as you recommended from Redline. (your right not cheap! 510 for the baja kit and another 70 for the correct headlight).
Thanks bro. I didnt do it myself especially due to the fact that i had the HID kit and Takegawa meter to wire in also,I would only take it to a Honda dealer as a last resort........there is no one else in your area?
#11 ·
Also, what do you mean by LED option? It says this on the website, is this what you mean:
*Standard turn signals may be substituted with LED mini-stalk or mini-flushmount turn signals. See the "Related Items" section on this page.
#23 ·
Ok guys, thanks a lot btw.
Can someone help double check me here. I see the page for the blinkers (G 15 and below it says F-25).
Do i need to order every part 1 - 9 or does that come as a complete set? Do they come in two's or single?
Also, i cant find the tail light? does anyone have the part # for this?
Thanks,
PS - already ordered the headlight from Redline, should i go back to him for these parts or Dan?
#24 ·
Thanks,
https://www.bajadesigns.com/NET/P-604190/Turn+Signal,+Standard,+Pair
per this page, you can purchase them as a pair/set.....this is the same style that I purchased with their 12-1300-WT kit
Looks like they have short stalks and flush mount as well....click the image to see the style.
https://www.bajadesigns.com/NET/C-TSIGS/TURN+SIGNALS+&+PARTS
I hope this helps.....
#25 ·
Thanks,
I have all 97/99 NSR50 JDM lighting Headlight,Tailight,Rear Blinkers and side blinkers all new including a JDM inner fender and tailight stay it is expensive but looks the best IMO.What kind of budget are you on?
#26 ·
Thanks manimal, i just ordered all of the parts (i got the OEM parts for the blinkers, headlight and tail light).
After i finish installing everything and KNOW for a fact that everything works out i am going to post everything. Exactly what i ordered, from who and include part #'s.....ok...just give me a couple of weeks.
Thanks,
Keith
