I just bought All Balls steering bearings and wanted to prep the bike for the install and can't seem to find a way to remove the inside race located at the bottom of the steering tube. It's the race the that the bottom roller bearing rode on. The inside diameter of the race is about 42mm and I don't have a puller that will do this size. I can't use a punch because the inside bottom of the steering tube is flared slightly. What can I do? Can the All Balls bottom bearing use the stock bottom race? Any help would be greatly appreciated. Thanks.
