how can i get more power out of my klx110 without boring it out?
15K views 8 replies 4 participants last post by  Branyers
i was just wondering how i can get more power out of my bike without spending the money on a big bore kit and carb. i already have a pipe on too which made a slight increase in power. suggestions?:confused:
#6 ·
mikeo228 said:
and if i was to get a big bore kit like
KLX110 KLX 143 BIG BORE KIT RACE CAM DRZ110 DRZ SUZUKI : eBay Motors (item 290291056349 end time Aug-14-10 22:34:44 PDT)
would i need a bigger carb. or is it not absolutely needed?
you can run this kit with a stock carb with just rejetting. You do need to go substantially bigger on the jet sizes. It'll run well and make TONS of torque, but will fall off rather abruptly in the higher RPM range. But it's a lot of fun to ride, especially on tight, backyard style tracks.
The pod filter will make a big difference over the drilled airbox, it will pull a lot farther up top, but will require rejetting also, but well worth the investment on a performance vs. dollar scale.
