I recently got a cheapo 290mm long 'Fast Ace' shock off Ebay for 80 bucks. It fit my stock XR70 with only slight modification. I had to chop off a section of the bracket that holds the seat down, but they still work. And I just needed some spacers for eyelets of the shock to get it to bolt down tight.
It came with a way way too stiff 1200lb spring, and I found a 17$, 390lb spring that fits it perfectly off Mcmaster that is part# 96485K211 . I just had to cut the old 1200lb spring off, as there was no preload thread left to get the collar off in order to get the new spring on.
Anyways, here are some pics. Just figured I would post it up so people can see how this cheap option works out. As you can see, I also got a cheap 'front end' kit and my bike is pretty raked out right now. Once I get a longer swingarm it should be pretty even. I would imagine that with the stock fork with BBR rods in it and the 290mm fast ace shock on the back, it would be pretty even.
