Daytona Anima 190 to Daytona Trex stator???
9.8K views 17 replies 4 participants last post by  size does matter
Hey guys ive never done this but i have a trex sittng here that i just sold and have been told that it has the lighting coil in it so my 190 can have 12v lighting circuit if i want. My problem is there is only one yellow wire coming out of it and ive been told and all the wiring diagrams on here show ligthing coils had a yellow and a white wire coming form them? Also do i need to switch flywheels or just the stator plate and keep my flywheel? Can post pics if needed but wholesale told me alot of guys have done this swap
#3 ·
The yellow wire comes out of stator wire harness and splits into 2 yellow wires that go into a plug that had a green wire in it as well but thr green wire is just a lead dangling there not hooked up to anything and the plug is not plugged in to anything. I'm hoping this plug is meant to plug into a 12v regulator/rectifier
#10 ·
Im not sure how to wire it if you have a 2 wire kill switch(i think thats what you are saying you have right?) If that is the case, you need to see if the switch grounds when the button is opened or pushed(there are two types of kill switches, one that grounds the hot, the other simply breaks the hot so no power flows) ive had my own issues with this, i had a 4 wheeler that was opposite of the honda 50 and used the key ignition from the honda. It would run when the key was in the off position and you couldnt take the key out when you turned it off lol. These engines use the type that when the wire for the kill switch is grounded then it kill spark. The easy way to check that its your kill switch is to simply unplug the kill switch wire from your harness and check for spark.
Hope all this makes sense
#12 ·
Ok on my bike absolutely nothing has changed except for the stator and flywheel this is on my anima 190. Has anyone did this swap they can please help me out so I can take my wife riding tomorrow I have everything wired as it was before I wrote everything down it is all pretty much color for color the pick up coil wires I connected to the other pickup coil wires and the two wires that were left I wired them to the other two wires I have tried switching all four wires every which way and get no spark on NEITHER motor? Will this even work Wholesale Cycle said people do it all the time?
#14 ·
I got the T Rex running but no luck on my 190... I replaced the coil and wire. I guess im going to have to buy a new stator and CDI because im not sure which is screwed up. Weird thing is all i need was pull the flywheel and stator off the bike and tried the trex one and when i couldnt get it to work i bolted mine back in and know no spark.
#16 ·
What i found is that the stator some how went bad from removing it from the bike???WTF So i went to Wholesale Cycle and the guys there Hooked me up with a new one no problem! Bike fired on first kick. So i never did get the trex stator to work and ended up putting my stator back in. It sucks because the trex stator and flywheel Is SOOOO much nicer than a anima stator and flywheel. Wish it would have worked or someone on here that has done it before would have given me some insight on how to make it work.
