4v head VS. Big 2 valve head
1 reading
7.9K views 10 replies 8 participants last post by  millbillyfiddy
I come from the race car world where if you could put a 4v head on something it would probably make alot more power. Seems like from some reading Ive done people say the v2 roller head with 2 oversized valves are better than 4v heads. Why is this? Or is it mis-information? The engine in the 110L is coming apart very soon for the case bore, so I want to make sure I put the best head on top of the 165 kit with a stroker crank.
#5 ·
That is true of the Chinese produced 4V heads. They take a lot of work to make good power. The Japanese 4V heads are a different animal altogether and make really good power. With that being stated, the TB V2 head is a great alternative to spending loads of cash on a proper Japanese made (rr built to a Japanese based company's specs) head. Good 4Vs make craploads of top end and rev to the moon.
#6 ·
If you are just bolting the head on, either one work ok. If you are building an engine and want the most performance out of it. The 2V head is a cheaper way to do it.
The 4V combustion chamber needs alot of work because the valves are so shrouded and the port design is less than desirable and needs quite a bit of epoxy to flow right.
If you want bling factor, roll the 4 valve but if you want performance. 2 is where it's at.
