110 semi auto clutch adjustment
35K views 16 replies 4 participants last post by  onlydirt
My 110 lifan is jumping into gear by itself and seems to be something a miss with the clutch. THere ios a large nut with threaded screw on the right side. IS there any quick adjustments to do to that nut and screw to fix any of my issues?
#6 ·
50-50 said:
The Lifan 110s (I think the actual displacement is 107cc stamped on the motor) do jump out of gear. It's more serious than clutch adjustment.
OK, here is my issue:
Jumps in gear and sounds like a clicking in the clutch or gears. WHen in neutral the front sproket ticks forward every so often, and its really hard to find neutral. Is this a split the cases issue? Rode fine, but the clicking noise when not on the gas scared me.
#12 ·
I can't tell you how to fix it because I don't know how, but I think this issue was covered on this site before. I just know my cousin's bike jumped out of gear and after doing some reading on this site I found that the problem is not uncommon. He got tired of his pit bike before it got severe enough that he had to fix it.
