Zongshen 125cc or lifan 125cc help
12K views 17 replies 6 participants last post by  dr650
Looking at buying a new motor and im on about a $250 budget and found these two motors whats the best option?lmk thanks!!
#10 ·
What stock engine you selling minimoto?
#12 ·
the honda motor is worth about $200 for the motor and harness assembly.
i woudl look at putting int he 140cc as shown, or at least the zongshen 125cc engine. the reason is, it uses a 13mm pisotn pin and Tbolt sells lots of pistons thatw ill bolt in, including cylinders to run up to 57mm bore. at a minimum you could get a 54mm hi-comp piston and bore/hone your stock cylinder to the new piston and have more power, then get a big valve head and your set.
the Lifan uses a 14mm pin and has fewer aftermarket parts for it.
but as mentioned i would get a 140cc and be done with it.
