Z50A Tapered Steering Bearings
9.3K views 8 replies 4 participants last post by  davmo
I'm looking to replace the steering bearings in my Z50AK1 and Z50AK2 with tapered steering bearings. I've noticed that most sellers/vendors don't list them as fitting all models. It seems that they cover the soft tails but not the hardtails.
- are the bearings different? If so, does anyone know who carries for my bikes?
- do the sets usually come with the cups, or do you re-use the old ones (this doesn't seem to make any sense). The kits don't appear to come with the cups.
Thanks for helping a newbie to Z50's
#7 ·
Thanks davmo, you answered the question that was rattling around in the back of my head, which was, "how does the race in the pictures fit where the bearing cup is?" I thought maybe there was a piece that wasn't shown that replaced the bearing cup once the bearing cup was removed.
So, next question, what can be done to improve the steering setup of a hardtail Z50? I found a bearing kit on eBay (Honda Steering Column Bearings Race Races SS50 CL50 CD50 Z50 S90 CL90 SL90 CT90 | eBay) that has the bearings contained and not loose. Other than making it harder to lose bearings would there be any benefit to using this kit, or perhaps it would be detrimental?
Thanks,
D
#9 ·
Thanks,
D
That's a good question. My instinct would be to say yes, it's a good thing. Seems to me being held in a ring reduces the amount of sideways (away from the center) movement of the ball bearings, but maybe someone has a better answer. As far as holding the balls together in the cup, there is a reason the loose ones are referred to as "Jesus balls." You can improve the steering on these bikes by improving the front forks. There is often a significant amount of play in these front forks, particularly if there is some wear on the components.. If you want to see a good example, look down at your front tire while stopping in a straight line. There are fork stiffener rods, heavier springs, and delrin bushings you can use. Another recommended part is the upper bushing you find on CT70 and later Z50 forks. It reduces some of the sideways play in the fork tubes. If you are riding on the street, a steering damper is one of my favorite things to take some of the twitchiness out of the front end.
if you want the upper bushing set-up, you would need two of each of the above.
