Z50 Carb question
11K views 11 replies 8 participants last post by  Fullthrottle
dayj1, electrical question....
on my Z50A-K1 1969 i got a battery with selenium rectifier.
the stator generate 6 volts... i would like to know what amout of watts that i can put on?
on tail light i will have two light. no switch brake. no flasher. and for front head light i'll had hi & low beam + small light on top head light.
difference between 12 volts & 6 volts is the bulb light? or wire are bigger or smaller? the stator is different i understand that... but there's other difference?
because when i bought tail light (twin) it's 12 volts light inside... if i change for 6 volts i'll be ok?
how many watts i could put on the system without burn it?
thanks!
