YX150 questions
3.7K views 42 replies 13 participants last post by  rlm996
I have recently purchased a used bike with a YX150 in it. When I got it home and rode it around a little it wouldn't idle, and it had a bad hesitation and back fired like crazy. It was around 28 degrees out so that would probably make it a little lean to begin with. My first question is would premixed gas make it run crazy lean at that temp? I dumped what looked like premixed gas out of the tank.
Also what is a good size and type of carb to use on this bike? I'm not too sure about the stock one. Everything is stock, no motor mods.
Maybe all this will work itself out when I get some new gas in it.
#2 ·
The cold will affect it but it would still at lease run.
toss in some fresh fuel and I would take the carb apart and clean it just to make sure.
If you wanna switch carbs, there are quite a few choices. VM26, PWK, TM, PE28's.
#3 ·
It does run.......kind of. It won't sit there and idle on it's own. It revs fair in midrange. I didn't run it out on top since it is running so flakey. It has mad popping on decell. I know an exhaust leak will make it backfire on decell. I haven't ruled that out yet.
Where should the air/fuel screw be set at? 1 1/2 turns open?
#4 ·
1 1/2 turns is a good place to start, but honestly I would clean your carb first before anything.
#6 ·
killer110 said:
mine backfired like hell when i got it and popped on top, but down low it seemed to be ok. My problem was my ignition was bad, and my motor was brand new from the factory.
Hmmm. That's good to know. How did it start? Mine seems to start fine.
#10 ·
Blackwoodz said:
hey rlm996 what did you buy? I have a 26mm MOLKT I got from firepower if you need a carb to try......or I would sell my real VM26 for a good price if you are interested. Where abouts are you located?
I live just north east of Elkhart Indiana about 15 min. I will mess with it a little before I decide what to do. What do you think you want for either carb? Thanks for the offer.
Jthomas7 said:
Might sound stupid but make sure the exhaust studs are tight at the head.
Ya, that's possible. I haven't checked that yet. Thanks.
#12 ·
From what I have been reading the ignition may be bad. Will an outer rotor from a zongshen fit? I have a new IRK that I just got for another bike from TDR. Maybe I will put that in there.
#17 ·
rlm996 said:
Ya I know. The kit has one in it. I'm pretty sure the motor I have already has an IRK in it. I haven't pulled the side cover off yet to look.
There are a couple different cdi's for the IRK's.....IFirst check to make sure the fuel and carb are good...then if still not right...start swapping the electronics........starting with a complete stock china rotor setup.
#20 ·
I may have missed the answer, but have you checked the pilot jet and made sure it is not clogged or partially clogged? That can cause the exact conditions you are experiencing - erratic idle, popping on decel, hesitation off the bottom, etc.
#21 ·
I took the carb off today and cleaned it. It wasn't too bad. Just a little green film on some parts. mostly on the bottom of the float and the bottom of the bowl. I removed both jets and replaced them with new. I took the main from a 100 to a 105, and the pilot from a 20 to a 25. I reset the fuel/air screw to 1.5 turns out. I also set the needle clip to the center (the needle was all the way down ie closest to the taper). I know that's a bunch of changes all at once, but I figured that's where it should be anyway. It runs better now. Not as much popping. I also installed a new exhaust gasket and new stainless acorn nuts. The plug does not show signs of being lean, but I have not yet ridden it outside (it's cooooold outside right now. like 18 degrees). I think I have it on the right track now, or atleast close. Now the only thing is that the exhaust header turns cherry red about 7 or 8 inches from the head when I'm running it. Of course it's sitting still in a garage warming up for several minutes. Maybe it won't do that so much when it's warmer. I dunno.
#22 ·
Its cherry red after a few minutes at 18 degrees....? sure sounds lean. When you pin it..does it hesitate comming off idle? if so forsure lean.
