muxster said:
So basically, you can run a 3.5 or 4" wide 120 tire if you use the G-Craft swingarm without the chain clearance issue?
Ok so let me get this down.
you can run a 4.0 with a 130 on a G-Craft wide type swingarm with offset sprockets.
you can run a 4.0 with a 120 on a stock swingarm with a added spacer or a G Craft wide swingam but you will have to run offset sprockets.
you can run a 110 on a 4.0 rim i hear as well with a stock swingarm with out offset sprockets. VMLOPES mentioned this.
you can also run a 120 on a 3.5 with out offset sprockets on a stock swingarm but your chain will be damn close to the tire.
lastly you can also run a 110 on a 3.5 or smaller with the stock swingarm no special sprockets and no clearance issues what so ever.
yes its confusing but i hope that helps
