What's next?
2.9K views 16 replies 10 participants last post by  jbullock305
Trying to decide what I should do next for my 110 build. Don't want to spend too much money on it but I want a little more out of the bike. Not sure if I should do the suspension or the motor, but can't afford to do both right now. Any thoughts? This is pretty much how it sits right now, but I just put on a red baron tall seat.
#6 · (Edited)
I dunno about the Float. I've never ridden with one before. I can tell ya from experience that unless you weigh more than 185, anything more than one BBR spring feels harsh. I'm going to try to add some travel with TBR damping rods with the stock fork springs to see how often I bottom them. I'll adjust up from there depending on how that goes.
If you're on here alot, then you may have read the thread where we talked about throwing the charts out the window when you're tuning KLX110 suspension. If you're a 70 lb. 9 year old-- then the charts would probably be accurate. Being that most of us are a great deal taller and heavier than that, we tend to ride further back on the seat than a kid who fits the bike would. So... I'm planning to go softer than what's called for up front, and slightly stiffer than the Race Tech charts say in the rear.
As far as componentry goes-- I'm planning on a custom sprung and valved Works shock out back, and a custom wound set of fork springs (possibly even a progressive rate if I can find somebody to do them) up front, in conjunction with some TBR damping rods to add some travel. Hope this helps. --L*64
#7 ·
Get the float I loved mine it's worth it and you can find them around 200 used
#9 ·
[h=1].TRC Cradle-Mount Frame KLX/DRZ110's & KLX110L
Part No: TRC-0819
[/h][h=1]
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
TRC Cradle Mount frame Adaptor fits KLX/DRZ110's & KLX110L
The kit comes with all the hardware to bolt it to your frame or you can have it welded on for added strength and protection.
Benefits:
* Added support to your motor (no more broken motor mounts)
* Added strength to foot pegs (no more bent foot peg mounts)
Features:
* Laser Cut Process
* Tig Welded
* Black painted coat finish
* Mounting hardware included
This modification to your Pit Bike or Mini is still AMA legal as an open frame setup.
Fits ALL KLX110 & KLX110L
DNM KLX110 Rear Shock (350)
Part No: WHS-1818
[/h]
SHOCK DNM MK-AR for KLX110
DNM Pit Bike shock with adjustable rebound.
Designed for the Kawasaki KLX110.
Uses a 350 lb/inch coil for adult riders.
270mm eye to eye
[h=1]10.65" eye to eye
BBR Heavy Duty Fork Springs - KLX110
Part No: 650-KLX-1105
[/h][h=1]
Custom-developed by BBR for adult riders. Pre-set and stress relieved for long life.
Fits KLX 110 stock forks or BBR E-6 forks.
• Increased spring rate for adults
• Preset and stress relieved for long life
• Custom wound from aircraft quality spring steel
• Fits KLX 110 stock forks
• Fits BBR E-6 forks 650-KLX-1105 are for use on KLX/DRZ110's from 2002-present
not including the "L" model.
[/h]
#15 ·
Part No: TRC-0819
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
Benefits:
Features:
* Laser Cut Process
* Tig Welded
Part No: WHS-1818
270mm eye to eye
10.65" eye to eye
What material is this cradle made out of?
#13 ·
Ive never ran a cradle on any of my bikes stock mods or full mods and never had a case problem, waste of money compared to just buying metric studs and double nutting the peg mount between them. Locktite would help also. But if you plan on jumping and casing jumps all the time or flat landing and your a big boy then yea. lol
Most times im sure they crack from the bolts becoming loose on peoples bikes from not checking and tighting them causing it to pull threads or crack the cases.
