1 - 4 of 4 Posts
lil mikey
Discussion starter · #1 ·
i wanna step up my 110 but i do not want to go crazy i ride in back yard and on the streets what is a kit that will be good?i dont want something that i will work on more than ride i just want to get on it and go.whats the diffrence between scut,os se or r
Yes I run a 134 kit with cam and vm26 mikuni carb. Stock-head kit. Runs awesome, low low maintenance, I actually run two but 1 with stock carb, Make decent power and really wake up the engine. Put on a Manual for even more performance like I did.
A good head/ carb/ cam will give you more power than a 134 with stock head ever will. ;-)
Best bang for buck, trail bikes 143 kit w/ head and carb
SE is kitacos performance head
+r is takegawas performance head
Scut is the type of cut on the piston specificly on the 178 kit. Its designed so you dont have to bore stock cases to accpet a larger diameter piston.
1 - 4 of 4 Posts
