Hey guys... below is a project I've been working on since november. I'm nearing completion and I've got a couple questions about gearing/carbeuration.
1974 CT70 Engine
150 psi compression
1978 Puch Moped frame
ATC70 4 speed transmission
88cc cylinder kit
Honda HOT cam w/ 5.1mm lift
19mm Dellorto Carb
CR80 forks
General 5 star moped tank
Yamaha FS1 reproduction seat
17" rims front and back
12v rectified/regulated electrical system (custom coil)
Halogen up front
LED in rear
egay clip ons
New jap valves
New gaskets
New seals
All new NTN bearings only
New cam chain
New points
I fabbed some stuff, and modded some stuff obviously.
QUESTION!!!
The 74' ct70 engine has an ATC70 transmission installed and an 88cc cylinder kit. I'm currently running 14x35 gears with 17" rims and a 17x3.00 tire in the rear. I'm finally getting it to rev out and go more than 30mph. But it's still a dog. The problem I think is that I'm not using a keihien I'm using an italian Dellorto carb - so I have no idea what the jet range is. In addition to the fact I've only tuned 2 strokes up until this. I've made great progress today, but just want to make sure it's not for nothing. I just want to know if it sounds like I need to keep fooling with the carb or lower my gearing. I have a 40t rear on the way and plenty of 44's around.
1974 CT70 Engine
150 psi compression
88cc cylinder kit
19mm Dellorto Carb
CR80 forks
Halogen up front
LED in rear
egay clip ons
New jap valves
New gaskets
New seals
New cam chain
New points
QUESTION!!!
