1 - 6 of 6 Posts
Customer Review :
[h=1]TRC Outer Rotor Ignition
Ultimate Full System
[TRC-0650][/h]
Date Added: Friday 04 January, 2013[h=2]by kevin m.[/h]
I bought this kit for my yx160 to replace the origional IRK that was a constant headache. After installation i went for a test ride and im very happy with the performace. The bike no longer stutters at high rpm and starting the bike seems a lott easier too even in cold weather . The harness seems to be great quaity and everything was the perfect length it was a complete plug and play installation. Another great advantage of this kit is the fact that if you ever want to run a headlight its ready to go with plenty of voltage..
Discussion starter · #4 ·
Customer Review : [h=1]TRC Outer Rotor Ignition Ultimate Full System [TRC-0650][/h] http://tboltusa.com/store/trc-outer-rotor-ignitionbrultimate-full-system-p-650.html Date Added: Friday 04 January, 2013[h=2]by kevin m.[/h] I bought this kit for my yx160 to replace the origional IRK that was a constant headache. After installation i went for a test ride and im very happy with the performace. The bike no longer stutters at high rpm and starting the bike seems a lott easier too even in cold weather . The harness seems to be great quaity and everything was the perfect length it was a complete plug and play installation. Another great advantage of this kit is the fact that if you ever want to run a headlight its ready to go with plenty of voltage..
Thanks a lot, so what are the advantages? Easier starting? Does it make the bike rev faster since it's lighter and smaller, and will that equal more power? And this will fit a Lifan right?
1 - 6 of 6 Posts
