I need to replace my timing chain. How do I remove the flywheel? I removed the 17mm nut, but how does it come off?
bstory1968 said:Is there a different puller that i can find locally?
phatfiddy said:No you cant fit an automotive puller behind the flywheel on one of these. If you dont use the correct puller you'll end up damaging something.
