1 - 20 of 40 Posts
not2brekinwit
Discussion starter · #1 ·
Ok heres the deal. I just installed the head, piston, carb, aftermarket filter and cylinder off a 06 crf70 on my 07 crf 50. All went well with the install but the throttle cable was way too short so i had to get one custom made for longer length.
Now the problem i'm having is that the throttle is way too twitchy. When i'm wheeling in 2nd it seems like theres a ton of bricks on the front end as it doest even want to come up. The idle after i let off the throttle still goes for a split second ( like you can still hear it rev for 1 second after i let off)
IT seems like the gears run out way too fast so that may be the problem. I have +1 in the front and + 3 in the rear which pretty much evens it out so i'm pretty much at stock gearing. Could this be the problem? Should i go down a few like 2 teeth in the rear?
It seems like the bike is just not running like a crf70 should as it is a bit faster but it doest go through the gears that long and its way too twitchy compared to my fiddy.
Anyone can give me some insight to whats going on? I'm already considering the rear sprocket going -2 in the rear back down to 38 but i was looking for some answers to see if anyone could give me more insight on maybe some tuning or maybe if the answer to if the motor is suppose to run that way?
Discussion starter · #35 ·
doopsx3 said:
to start anyway...turn ur idle up so it will idle cuz it will probably run like poo...turn the air adjust screw out till it idles the fastest and then back in just a bit...if it never changes then ya have jetting issues or the pilot is dirty
i just turned it right all the way and turned it 1/4 turn so far and it seems like it runs way better
1 - 20 of 40 Posts
