Tb vs.chp cable clutch?
2.5K views 14 replies 8 participants last post by  speedy mendeavel
Is the chp worth the extra $50 over the tb?
#3 ·
Thanks! Im stuck between tb and brand x minis hydro.. Iv herd stay away from brand x but its such a good deal and i dont understand why its worse than a two bros hydro... Whats the diffrence? The brand x has a magura cylinder
#7 ·
if u dont have the money for the used hydros on here or the new two bros/bbr/chp hydro ones then go with the either of the cable clutches. I personally have not dealt with brandxminis but i have heard stories about them leaving out parts specifically when it comes to their hydro clutch.
#9 ·
check this kit :
[h=1]DRZ110 KLX110 Manual Clutch Kit - Full Manual
[TRC-5258][/h]
  • Image
  • Image
Like hydraulic actuated clutch kits on the market today, this kit uses the stock clutch. However, the similarities between the two end there. It's much easier to install with no hassles of bleeding lines and you never have to worry about the loss of hydraulic fluid during a ride or race.***UPDATE*** The kit now inlcludes a primary clutch removal washer that allows you to convert to a full manual clutch if desired. Use of this washer also removes two pounds of weight off the crankshaft resulting in quicker engine response.
Primary Gear
Same gear cut as stock for silent operation
The TB upgraded 22T primary drive gear for KLX110
Eliminates the front centrifugal clutch & reduces crank weight
This product is to be used in conjunction with Manual and/or Hydro Clutch conversion kit only.
NOT for 2002 KLX110
Outlaw Quick Adjust Lever
Outlaw Quick Adjust Clutch lever - Full size
Full Size Top Quality Race Bike Clutch lever with On the Fly adjuster
Billet Case Cover Red or Black
Very nice anodized CNC machined billet aluminum cover for the Manual Clutch Kit case.
Will NOT fit stock KLX110 clutch cover
  • TBW0343 - Clutch Kit
  • TBW0858 - Primary Gear
  • TBW0460 or TBW0461 - Clutch Cover (Red or Black)
  • PP180 - Clutch Lever
