1 - 4 of 23 Posts
Standard head gaskets are in the 1.4mm range if I remember correctly.
Chinese mills normally use 'short rod' or 6v style pistons, roughly a 19.5mm pin height (measured to the center of the pin.) Later Honda motors, and some cranks like TB's 51mm stroker use 'long rod' or 12v style pistons which are roughly 1mm shorter, with an 18.5mm pin height.
1 - 4 of 23 Posts
