Synthetic oil?
8K views 18 replies 11 participants last post by  T Bolt USA
Do y'all use it in your bikes? Some say you can some say you can't?
#5 ·
Rotella t6 is synthetic and I'm going to switch over to it.
The white is Dino, the blue is full synthetic and both are jaso ma certified.
The grey bottle semi synthetic isn't.
#7 ·
I've run synthetic in ALL of my bikes (both sides on big bikes) for years, and never had the first problem with clutches slipping. The only issue I did run into is Redline synthetic oil eating Chinese clutch rubbers. Went through 3 daytona baskets in 3 days/rides each.
#11 ·
Yes it can take 15/40. People run 20/50 in small engines
  • Like
Reactions: Raym
#15 ·
I run Amsoil A - because its on my dads shelf at cost for me ...B- because the type I run it is specifically designed for wet clutch motorcycle engines.....never had a problem yet & our china bikes take a beating on the regular.... when I check it and it looks like crap I change it (need to get hr meters)
from what I have gathered (from 3 different oil reps n a bunch of reading and watching the amsoil bashing lol ) Its more about picking the right type...(not brand) and not contaminating it with any other ....ie pick one and stick with it - just make sure it is designed specific for a wet clutch 4 stroke ..and change it when needed
#19 ·
OR
[h=1]Maxima Maxum 4 Premium 4 Cycle Oil
Part No: 34901
[/h]
This is our recomendation for Larger YX ZS type Pit bike engines
Maxum4 Premium Premium Petroleum Blend Non synthetic
Promotes good clutch action
Smoke resistant break in qualities
4-Cycle Motorcycle Specific Oil 10w40 Maxima’s Maxum4 Premium is a superior product featuring advanced additive technology in the development of highly stable and long life multi-grade motorcycle specific oil. By using an exclusive blend of petroleum base stocks and advanced anti-wear, anti-shear additives, this product assures viscosity stability for 4-cycle engines with integrated transmissions. This formula also has extra anti-scuff additives to handle extreme loads and peak temperatures in high performance engines. Premium Petroleum Blend
