41 - 60 of 105 Posts
Discussion starter · #42 ·
got the taillight at a local bike shop. i think it was like 20 bucks. i got it to put on an old suzuki i was fixing up, then realized it was'nt dual filament so i could'nt use it. since i'm not running a brake light it worked out perfect for this bike
Discussion starter · #44 ·
makotosun said:
The bike is looking GREAT! I love the fact you did the paint from a fizzy can and it turned out looking better than a lot of pro custom stuff I have seen.
Great job!
thanks man! i was surprised how well it came out myself. gotta hand it to duplicolor, they make a pretty decent puff paint! their clear coat leaves a lot to be desired though. once i'm done with the loose ends i'm going to take the bike apart and hit everything with a quality auto clear. it should reallly pop then!
I use a lot of Duplicolor too. Really nice quality for the most part.
Have you ever tried the Spraymax two stage clear in the fizzy can? It is available at auto paint supply shops or online. It is designed for use by pro auto repair places when doing small jobs. Not cheap at $15-20 per can, but on these projects it could work fine.
I did think I read above that you have a friend who can do it for you, so maybe that is not an issue.
Link for the stuff is here: 2 Part Clearcoat 11.8 oz. Aerosol They have a quick dry version also 2 Part Rapid Cure Clearcoat 11.8 oz. Aerosol
Discussion starter · #46 ·
thanks for the links. the sad thing is that when it was all said and done, i spent more on puff cans then i would have if i had bought real auto paint,lol. this project was a good learning experience in a lot of respects, one of those lessons is that i will puff can no more!
i'm planning on throwing down on a decent compressor and a couple paint sprayers this winter as i have caught the building bug big time and want to do my future projects with a little more efficiency and quality.
reilly118 said:
Got this baby up to 51mph, 3speed honda with tb108 kit.
Cant wait to see what my 4speed jailing with tb146 kit and race head will Do.
what gearing are you running with that 108? i'm running the lifan 146 BVH motor and it will power wheely in all 4 gears, so i was thinking about making the gearing a bit taller.. it roughly does abotu 50 right now. iT definately needs better shocks before anything ver that though.. the rear end floats around bouncing all over in the top of 4th due to lack of dampening. ( got a stock CRF shock on the rear right now)
I need a swinger like the one you got as well....what brand is that? i like how it still goes well with teh stock forks.
The gearing is stock thats why yours and mine go the same speed i thing im going to run 17 32 in the new engine.
The shocks are kitaco 305 (not stock) and the swinger is a daytona +4cm
(contact Z aka dan and see if he has anything for you)
The black motor should look nice...Besides everyone has different tastes...There are a few on here that like pink plastics and whitewalls...:confused:...To each his own right ?...Chris you should have your own "build thread" unless this one is your official "build off" ???
