!!!!still cracking oil filter caps :(!!!!
6.8K views 25 replies 18 participants last post by  Josh55
Weird problem!!! Please help!
Hey guys i have a 2003 klx 110. All i have done is a fmf 4.1 exhaust. I have had 2 oil filter covers just bust on me the past 3 weeks!!!
I am running a skid plate! They are breaking within 15 to 30 seconds after start up. Any ideas of what could be going on? Thanks!
#7 ·
That motor does not push enough pressure to break the cap. Something is not installed right or lining up right. When you put the filter on and put the cap on...you should be able to compress the spring and push the whole filter cap flush with the motor with your hand. If not something is wrong. If this is the case than the only thing I can think of is way over torqueing the bolts?
#10 ·
Yes - non OEM filter will cause this. The OEM filter has a recess on the top (opposite of the rubber part) this recess allows the bowl to go all the way on without the bowl hitting the filter. There are filters that are ALMOST the same...but they do not have that recess. If your filter did not come in a green and black box and say Kawasaki on it then its not OEM. Even if it is OEM you may have the wrong filter still. The only possible thing I can think of is the wrong filter is being installed. I got one from a local dealer that was "cross referenced" and it looked legit. When I tried putting it on I was not able to push the filter bowl flush with the motor as I mentioned earlier for you to try. I immediately stopped to investigate. There was no recess in the top of the filter causing not enough room for bowl to go all the way on. Had I just torqued down the bolts I would have broke the filter bowl where you are describing. I think you have the wrong filter. Save the one you have - get an OEM one - compare them side by side - I bet they are different.
#12 ·
Does anybody out there think it is a possibility that my engine case could be warped where the oil filter cap comes in contact with the case? I can't seem to figure out why I keep breaking covers. Please help!
#16 ·
Geezer and I looked at a set of KLX cases today and your issue was discussed
He said you may have use too thick of an O ring , and the mounting bolts are like 9 in / lbs (double check your manual) so you only need a 1/4in drive or nut driver to put them on
#21 ·
I'm using a bikemaster filter and I don't have any problems with cracking the cover. If you need a oil cover I have one
