How many of you guys out there are slammin' these things around pit bike tracks? How well do they rip/hold up? Anyone got some video? I would love to see a KX or RM 65 with a big bore kit.
Kendellgil said:How many of you guys out there are slammin' these things around pit bike tracks? How well do they rip/hold up? Anyone got some video? I would love to see a KX or RM 65 with a big bore kit.
SUZUKIRM12594 said:I'd imagine my dream 65 pitbike with
tall seat
KLX bend bars
Zokes
Excel black rims
HD spokes
Fastway pegs
Blue Plastics
Blue gripper seat cover
STR/TNP graphics
Procircuit Pipe/
R304 Shorty
pod filter
82cc BBK
etc.
that would be so insane! That gives me some ideas.....kxrider425 said:Or stuff a yz85 motor in one of those frames and bore it out to a 105. Now your talking..
BigMamaJama610 said:that would be so insane! That gives me some ideas.....
Luckystar64 said:The front end (stock except with .36 springs per PR2, and 10wt. oil 110mm from the top with the springs out and the forks compressed) works pretty well over the small braking bumps and small stuff, but when I go bigger-- it acts weird on the landings. It kind of acts like I have too heavy of springs in them. It seems like the holes in the damping rods that control compression need to be bigger to allow the oil to flow through more quickly to let the springs compress and absorb the landing. It's like they go into "fluid lock" mode. Also-- they tend to rebound a little bit too quickly due to the heavier springs. (the stock spring rate is .28, I'm running .36 springs). I'm wondering if the holes for compression need to be drilled bigger, then the rebound holes need welded shut and drilled smaller. --L*64
HI-TECH HORSEPOWER said:KX 65 .080 Big Bore Performance package
OVER 19H.P. BUT WHATS REALLY IMPRESSIVE IS THE TORQUE ITS AT 8.5ft lbs OF TORQUE,AND THE TORQUE SPREAD COVERS MORE THAN 1200 RPMs IN THE 8ft lb RANGE.
If you would like to see the Dyno sheets they are posted on ebay.
Luckystar64 said:I was kinda thinking about Pax's cartridges in the forks. The issue I have with that is they're like... $450? For another $250, I could get a set of Zokes. and then probably get $200 for the stock 65 forks. --L*64
stik__boy said:I can get you 19hp out of a bone stock KX, with a good clutch dip. I don't believe it, and I don't care what the run says.
then you could just bore the 65 motor to 85stik__boy said:already had a motor, measured it up.... wont fit with out hacking frame.
