rear handbrake for klx110
1 reading
8.4K views 20 replies 15 participants last post by  josh302
can someone tell me how to make a rear handbrake setup for my 110 or where i can buy one?
thanks
dylan
#6 ·
lil mikey said:
i dont see anything on their site is it avaliable
I don't think its available yet
You can try ghettoing your own setup up, thats what I did on my 150f for hte short time I had a hb
By ghetto, I mean just using whatever cable you can get thats long enough, wahtever clutch lever, a Hose clamp to secure the cable to the swingarm, and a peice of steel, or weld to the stock brake arm
PM me if you need more specific directions :)
808stunna said:
50stunt products are top notch.
+1!
#21 ·
here is a setup I made for a 150
I used a honda rear brake cable off of an old school 3 wheeler(in stock, 16.00 at steelership)
Welded a tube on the rear brake rod, I made a u-shaped bracket that bolted to the swinger and held the cable. been workin for years.
Pretty easy fab
Run the clutch on top with a short or cut off lever and run the hb on the bottom
