Oil slinger off yx150
6.7K views 14 replies 5 participants last post by  pitsterprofla
hey guys one off my screws cam off my oil slinger and the whole thing broke into little pieces.Marked the clutch basket a little bit but that should be ok hopefully,Anyway i got a 125 engine and was going to use that oil slinger.Does anyone know if its clockwise or anticlockwise to get the centre main nut off?Please help
#4 ·
Since you're in NZ there are two sellers of 1 piece CNC alloy slingers on ebay OZ ... The only thing I don't like about them is that they're machined to a sharp corner which could possibly form a stress riser ... They'd be better off if they had a radiused fillet ...
BRAND NEW CNC ALLOY OIL SLING & GASKET LIFAN 110-150CC - eBay Other Makes, Bike Parts, Motorcycle Parts, Accessories, Cars, Bikes, Boats. (end time 27-Jan-09 16:24:16 AEDST)
NEW LIGHT WEIGHT CNC ALLOY OIL SLING DUCAR LIFAN 140CC - eBay Other Makes, Bike Parts, Motorcycle Parts, Accessories, Cars, Bikes, Boats. (end time 17-Jan-09 20:51:57 AEDST)
#6 ·
A machined steel slinger will be super reliable ... I was referring to where the outside surface of the splined section meets the start of the flanged section ... You don't want a sharp corner at that point because it can cause a crack to start ... especially in an alloy part ... Use a radiused tool tip ... You should always remove sharp outer edges so people don't get cut ... that's a standard machinists rule ...
Here's a link on how to lighten steel slingers ... the overall length of the steel slinger should be left stock ...
http://img481.imageshack.us/img481/1653/volant20lifanxn1.jpg
#8 ·
#10 ·
foxman said:
Does it matter it being bigger than stock though?
no,,,,you will just rev up slower but it wont hurt
history lesson 2005-now
basically the older gpx / jialing and lifan 120/140 motors had the large heavy oil slingers/filters
then
we machined them down at first until an aluminum unit became available
and these worked better and held up good on the gpx 124cc type motors
but
the yx150/160 motors like to break these aluminum units
so we went back to steel units trimmed to the lightest possible
my recommendation after doing this a great number of times
gpx124cc/yx140 = aluminum slinger
yx150/160 = steel slinger / turned or lightened
#12 ·
