Well today was our first race and a shakedown of my new to me Piranha 190 that had a short but rough life as documented in the Chinese forum. This is basically a stock bike, but I added Workz wheels and the shorter (by 15mm) shock off my SR160TX and some GSXR pegs. I also raised the forks to lower the front end. Right away the issue was ground clearance. The pegs on these bike are already lower than most other bikes so that made it all the worse. Also because the seat is tall I wasn't able to hang off as much as I could have also reducing clearance. Damn near wore thru my new boots!
The motor was strong, very strong so I had plenty of power to point and shoot it out of corners which was all I could do. What I also noticed is the increased stability, turn is a way less twitchy than my TX which was expected with a perimeter frame. I really like that trait so I'm going to see about raising the pegs and cut down the seat because this could be a bike to contend with. As I turned out I still got on the box (3rd overall) mainly because of my skillful blocking of guys I was able to out drag at the start!
Since this was a kart track I also put it on the scales. 175# with 1/2 tank of gas. About 10# more than an SSR TL frame with 190 motor, but since I'm 152# with my gear I still have a power to weight advantage over everyone else. The development continues...
