lifan 150 to 125
1 reading
3K views 4 replies 5 participants last post by  T Bolt USA
sounds strange but would just like to know if it is possable to reduce the bore size to make it a 125cc and if so which barrel head and piston would be best will need as much power as possable but needs to be 125 from a lifan 150 as i already have this motor thanks
#3 ·
Are you trying to tame it down, or are you one of those "Rule Follower" guys?
De-stroking the crank, or at least swapping to a 55.5mm Lifan 120 crank gives you some bore options, that would allow a bored 120/125 52.4mm jug. The 150 stroke has you in the 51mm bore range. Should be able to do the build for a couple hundred bucks.
#4 ·
Hi everyone. Im thinking of buying a new engine. Considering higher speed and quality which one would be a better option? A lifan 125cc engine or a lifan 150cc engine? My friends and mechanic advised me to buy the lifan 125cc engine instead of the 150cc engine. They told me that the lifan 125cc engine is more powerfull(speed) and resistant(durability) than the lifan 150cc engine. Still i am in a doubt and i need good reasons. Can you please help me choosing the engine. Thanks in advance.
#5 ·
[h=1]*Piranha 140cc Engine
fits Pit Bikes and other Minis
[WHS-1143][/h]
YX140cc
This is our best selling engine
Top performance and economy all in one
Super sturdy and Very strong running engine
See picture for parts included , only as pictured.
Great Replacment engine or for builds & Projects.
Includes:
Engine
Carb
Intake
CDI
Coil
Harness
Kicker
Shifter
Engine
Displacement140cc
Engine TypeAir Cooled, Single-Cylinder, 2-valve, 4-stroke
Bore/Stroke56mm x 57mm
Final DriveChain
Fuel Delivery22mm or choices listed below
FuelUnleaded / 93 Octaine
Reccomended Engine Oil10W-40 Petroleum Based (Nonsynthetic)
Ignition
Kick StartYes
Electric Startno
CDIYes
Auxillary OutputYes
Transmission
Transmission4-Speed Manual 4Up
Shift-PatternFour-speed Transmission: N-1-2-3-4
ClutchRear 5 plate manual
Note:
When upgrading your Honda XR50/70 ,CRF50/70 to this engine you
may want to use order aftermarket footpeg mounts and tank spacers.
Also we suggest using an aftermarket exhaust to obtain maximum performance.
All of these items are availble at TBoltUSA.com
Engine Specs
Bore:56mm
Stroke:57mm
Displacment:140.4cc
Big Valve 27mm/23mm head
Gears:4 speed ,bottom neutral 4 up shifting
Carb:22mm mikuni
Ignition:Standard Flywheel ignition
Kit Includes
Carb
Kicker starter
Shifter
Electrical components
Not Included
Skid plates
Exhauste
Air filter
Carb choices:
Stock 22mm mikuni
VM 26 Mikuni
No carb
Note:Spigot mount adapter boot is included with Upgrade VM26
