OLDSCHOOL said:
what type of oil are you using?
So far in this Lifan 150 I have used: 75% Shell Rotella 40w15 mineral (diesel) oil + 25% Shell VSX4 synthetic. Actually Australasian Shell product: Rimula-X oil which is very close to Shell USA Rotella in standards and the exactly same in terms of market purpose. btw: I ran in for 20 mins with 100% mineral oil, and I took it real easy on the gears at that stage.
Actually I use the same oil mix in my KX450F specifically because out of about 4 different specialist 4T bike oils (Motul 7100, Silkolene, 100% VSX4, Motorex 4T), I found this to give me the best shifting and clutch action in my 450F. Possibly less mechanical noise too. Actually Motorex was fine, but more expensive. Motul 7100 lost way too much viscosity and gave me the most radiator overflow (heat) so I will never touch it again. I trust "my" oil mix and diesel oils in general. I run a neo mag drain plug in my 450 too, plus I open up the used 450 paper oil filters, and I find the engine loses practically no metal at all, shifts great, nor do I get valve wear and it has done 70 moderately hard hours.
The 150 wear might slow down. I think this Lifan is going to wear a little fast no matter what. My Lifan 140 was exactly the same. Just no proper oil filter on the 140 so the mag plug always had a lot of metal on it. I always warm up gently, and I always full clutch in to shift up or down, but then I ride it wide open a lot.
The Lifan clutch slipping issue will be fine/solved. I have stiffer springs and tougher fiber plates ready to go in.
It's just so much fun to ride with this A1 bottom end cam in! Particularly with the bad Lifan wide ratio gear box (2nd to 4th and forgetting 1st) on wooped out and rutted MX tracks. If it blows up, I'll just by another and put the same head on the next one.
As well as doing laps, I was tearing around a large patch of damp sandy soil in constant 3rd gear, and it just rips. I have Pirelli MX Scorp extra tires front and rear. Plus a large air filter mounted up under my seat.
