Kx60 vs 110L forks
5.6K views 10 replies 5 participants last post by  Dragit86
What's the difference in the kx60 forks and the stock 110L? Does the 60s hang lower under the axle than the L's. Iv got a 08 with stock forks and trying to put a setup together. I want more ride height after riding my buddys 110Ls but can't find any stock 110L front forks for sale anywhere? But also heard the 60 forks are sprung really soft.
#4 ·
Not worth the money. Want forks as good as E-6's? Just get KX 60 forks, powdercoat them black, and get stiff springs and an extended brake cable. The 60 forks have a good 5.5 inches of travel and with stiff springs they'd be very nice.
#6 ·
Yea I can't find any stock 110L forks for sale figured someone would be parting one out somewhere. I figure the 60 forks gotta be better than stock so might try and snag a par and run them for a bit and save for some stiff springs for them.
#7 ·
e6's are damn near the same as slightly modded 60 forks. if you can get the e6's off the fasterminis kdc, you can snag them for 300 shipped, which turns out to be about the same price or maybe a little less then buying 60 forks and modding them.
#10 ·
run kx60 forks with aftermaket hard springs they are great, they are hang slightly lower at the bottom, most my friends run these, the lighter ones only run one hard spring in each leg and other standards, ours work great with elka's
#11 ·
Yea I picked up a set of kx60 forks from a guy on here. Gonna run some stiff springs and just run the up in the triple a bit, I got the dnm rear shock for now its like a inch longer than stock so I think it will work pretty good. Does anyone know where I can get stiff springs for the kx60s that arnt longer than stock I dont need it any taller. How much shorter are the stiff springs for the 110Ls could I put them in the 60s with mabye a spacer?
