Kitaco inner rotor kit
1 reading
9.1K views 10 replies 7 participants last post by  tommy o
Does anyone know if these are junks or not? I recently bought a cheap Irk off ebay to see if I liked them and it didn't even work. I want to turn my bike into the full race bike so any suggestions on getting this. Thanks.
#4 ·
I don't see it really increasing horsepower. It just increases the way the bike revs. People say unless you ride wideopen all the time, they're awful in corners.
#5 ·
Yeah they're worse with bottom end because you don't have the momentum of a heavier flywheel to pull you out of the corner but then again that doesnt make sense because you are picking up rpms quicker which would seem like it you would be taking off quicker. What other mods do you suggest that will make my bike hit a little harder than it already does?
#10 ·
Have the Takegawa inner rotor kit and clutch on a 106. Agree with the above about great on the top end, not so much on the low end. At first I kept killing my engine because i was used to all the inertia of the flywheel and clutch hooked directly on the crank in the stock set-up. With the extra weight on the crank, it takes longer to get to max revs, but it also helps at lower speed, because there is more momentum retained in the engine. If you are using a lower cc engine, and tend to always be WOT, you might like the inner rotor. With a more powerful engine, not so much. Some people don't recommend the inner rotor unless you have one of the Daytona or takegawa style clutches. The idea being that if you are taking weight off one side of the crank, you should take it off the other side as well. Don't know if that is true, but seems reasonable to me. There are guys who lighten flywheels (just got a couple done at FPM,) which might be a good compromise for you.
#11 ·
They are great !! If you know how to ride !! Ive been using 1 for 5 years no problem !! They make it alot snappier , revs quicker , harder to kick over . If you ride on small little tracks or cruise in the pits i would pass , but if you want to race get it ! kitaco on 3or 4 diff 110s , i even have a flywheel weight for it , never use it . GReat product !!
