I need some help from you guys with the 28mm Keihin FCR Downdraft Carburetor. Can you guide me in the right direction on the following questions listed bellow -
Jetting - I need a jetting starting point?
Engine Information -
*General - Custom Built 184cc Electric Start w/ Back Up Kick Start Big Bore Stoker Engine built by Pitster Pro "USA Motor Toy's LLC" in there Race Engine Program.
*Displacement - 184cc
*Port/Polish - Withrow Powersport's WPR Aggressive MX Port/Polish
*Head - TB V2 Roller Race Head
*Cam- Custom Race Grind/Profile done by Pitster Pro
*Valves - Custom Titanium Valves --- Intake 28.5mm --- Exhaust 23.5mm
*Springs/Retainers - ZS Heavy Duty Racing Valve Springs w/ Ti Retainers
*Piston - 13.5:1 High Compression Pro-Lite Cast Aluminum Piston
*Crankshaft - Long Rod Stroker Crank
*Stud Kit - Kitaco Forged Cylinder Stud Kit
*Exhaust - FMF 4.1 Titanium Exhaust System (Big Bore CRF-50/70)
*Carburetor - 28mm Keihin FCR Downdraft
*Ignition - Dynatek Programmable Digital 4-Curve CDI Box w/ custom timing curves (TRX-400EX), Dynatek Miniature Series Coil (TRX-450R), Accel 8.8mm Spark Plug Wire, NGK-IX Iridium Spark Plug, Lightweight Flywheel,
High Output Stator, & Mini 6-Cell Lightweight Lithium Battery
*Air Filter - K&N Filter w/ Outerwears Pre Filter
*Timing Chain - Kitaco Heavy Duty Timing Chain
*Clutch - 4spd Manual HD Clutch Kit, Billet Clutch Basket & Rekluse Z-Start Style Sport/Auto Clutch
Please help me out on a starting point for the jetting, It would help me out a lot.
Thanks,
Jim
