I'm having trouble jetting my tb 28mm carb on my pitster x4.. it has a yx 160 bottom end.with a 177 bbk. Stock head.daytona type outer rotor.chp coil.I'm at bout 4365 feet elevation..iany help thanks
Well it was bogging down when I have it wide open...and even worse when in the air and give it gas...so today I put a 105 in to try when out to ride it and. It seems to ride a little better then when you pin it and shift to second gear it sputters then like catches up and goes..and the bog that used to happen isn't there any more..but pulled my plug and its still alittle charcoal black...so do I want to move the clip in the needle up one...just worried why it sputters and then catches up when shifting to second wide open.....
Ya I've ben cleaning it with a wire brush..um it mabe has 2 hrs on everything...I've checked clearance its good.it pulls a lot better sounds a lot better.it only boggs and sputters when I'm wide open and then shift in a nother gear soon as I let the clutchout in that higher gear wide open it sputters and then like catches up..so I was thinking to try a 110 and put needle in the middle and try that..what do you think..lol
So do u think I need to get a couple smaller pilot jets to..it usually starts on the 4th or so kick..id like to help that area if I can to.....and what size do you think..
Ok its dam close now..I was so stuck on changing the main....but put a 102 main and 44 pilot..needle in the middle.and mix screw is a. Hair over 1 turn out....pulled the plug and good shade of brown...so I'm happy with it....thanks for all the info..all though didn't pay attention to all of it..lol..but goter done..
